The new “Record and Email” component allows recording audio from the caller, and sends it attached to an email message. If the recording is finished because the caller hangs up, the email will be sent without needing to add any component to the Disconnect Handler flow, simplifying this very common task.
Another very common need when using the Date & Time conditional component, is the ability to set date ranges. For example, when an office is closed for 2 weeks, instead of adding a “Specific day” condition for each day, you can use a “Date range” condition. This new condition will be met when the date is between the “from” and “to” dates specified (both included), and the time is between the “from” and “to” values.
What else is new:
- Added new regions for Amazon’s Polly TTS engine.
- Added Date range to Date & Time conditional component.
- Added new CFD Function CONTAINS.
- Added new Record and Email component, allows recording audio from the caller and sending it attached to an email message.
- Fix to EMail Sender component, which was not properly sending HTML body after upgrade 3 of 3CX v15.5.
- Fix to EQUAL function, which was returning false when comparing an Int32 and an Int64 holding the same numeric value.
- Fix to the flow execution logic, which now executes the Disconnect Handler flow when the call is dropped by the app when all components from the main flow have been executed.
- Fix to dialers: variables were not being reset to default values for each dialer cycle, keeping history from previous runs.
Download Link and Documentation
Download the Call Flow Designer here
Read the manual here
View the complete Change Log
