Update 10 makes AI call summaries more useful by adding notes and action items.
A call summary should tell you more than just what was said. With V20 Update 10, 3CX AI call summaries now include Notes and Action Items alongside the existing summary.
This gives support, sales and other teams a clearer view of the call outcome, important context and what needs to happen next. No need to replay the recording or search through the full transcript to find one decision or follow-up task!
From Summary to Notes to Action Items
The updated call analysis is split into three clear sections:
- Summary: What happened during the call
- Notes: Important context, decisions or useful details
- Action Items: Tasks that should happen next
This makes it easier to understand the outcome of a call and pick up any required follow-up. For example, if a customer calls to ask why a service is delayed, the summary can show what was discussed, the reason for the delay and any next step agreed during the conversation.
Supported CRM templates already include 3CX AI-generated transcription, summary and sentiment when journaling calls. In Update 10, that summary output becomes more structured, which can make CRM call notes clearer and more useful for all involved.
Updated AI Summarization Prompt
Update 10 also improves how the AI decides what belongs in the summary. The updated summarization prompt is designed to ignore content that normally does not affect the call outcome, including:
- Greetings
- Small talk
- IVR menus
- Hold music
- Technical noise
These are only considered when they are relevant to the result of the call. The AI is also instructed not to invent action item owners, dates, decisions or tasks. If no useful notes or action items are found, the relevant section will show “None”. If there is no meaningful conversation to summarize, the summary will state “No meaningful conversation.”
The result is a shorter, cleaner call recap focused on the information users need.
3CX AI Call Analysis V20 Update 10
Structured summaries can help teams quickly see:
- What happened
- Which details matter
- Whether any follow-up is required
This makes post-call review easier across support, sales and other teams using 3CX AI call analysis. Update to V20 Update 10 to take advantage of the improved call summary format.
Join the Discussion
