V20 U5 maintenance updates for regular and router Yealink phones.
The latest IP Phone firmware updates for Yealink - containing maintenance updates - have been released and are fully tested with V20 Update 5.
Yealink Firmware Updates for V20 Update 5
Normal Phones
- T3 Series - T30P,T31G,T31P,T31W,T33G,T33P,T34W - v124.87.0.15
- CP Series - CP925 - 148.87.0.15 & CP965 - 143.87.0.20
Router Phones
- T4 Series - T42U,T43U,T44U,T44W,T46U,T48U - v108.87.0.16
- T5 Series - T53,T53C,T53W,T54W,T57W - v96.87.0.16 & T58W - v150.87.0.15
- AX Series - AX83H - v180.87.0.6
Important Note: Yealink has fixed some of the DST issues users were reporting, but they’ve made it clear that after the upgrade, you will need to factory reset and then re-provision your phones for the DST fixes to apply.
How to Upgrade Yealink Phones
Upgrade your IP Phone firmware directly from the Admin Console in your 3CX. Navigate to “Phones” > “Upgrade”.
Alternatively, you can upgrade from the Users page of the Admin Console. Navigate to "Users" > Click on a User > select the "IP Phone" tab > "Upgrade"
Join the IP Phone Forum for discussions. For specific questions on this update go to the dedicated Yealink Forum.
