Solved How to mute incoming calls from the SIM card when I'm in a conversation on the 3CX app?
Arthur.b
Platinum Partner
It's all in the title!
I am looking for a solution to prevent incoming calls from my SIM card when I am in a conversation on the 3CX application.
It's quite annoying to have a ringtone during a conversation.
Hello Arthur.b,
Please fill in the details, for it to make sense.
How is the 3CX setup? Hosted own FQDN, software version.
Type of device used iPHone/Android Firmware version, software version OS version whatever you can find on details matter.
Paulo
Reactions: bitn2
Make sure Telecom API is enabled (Settings > Advanced)
If this setting is on, you will just get a subtle beeping sound from your incoming GSM call
Hi Paulo,
3CX hosted, in last version V20 U8
Android device, on android 13.
Hello Arthur.b,
Paulo
Thanks you ThomB. its works ! Does it works on iOS also ?
Reactions: paulodagraca
@Arthur.b on iOS this option does not exist as the phone does this automaticaly by itself.
So when you are on a 3cx call, the GSM call will just be on the background, like a 2nd call.
Check it out.
Thanks you Nikos !
You can mark this thread as "resolved"
