Need a Logout & Login via Desktop App
IMI
SOHO User
Unless I am missing a place to do this, there seems to be a major hiccup in the desktop app...
It seems as though the only way to login a new user is via a web-browser and you cannot log out a user in a desktop app (to have no user logged-in). That is an oddly disparted flow.
Simply adding a logout & login would be an expected option within the desktop app; prefer a feature for auto-logout or ability to select from many Users of which a login needed each time. Consequently, currently if a user forgets to logout via browser another user has full access to their profile.
Hello @IMI The use case for the Desktop application is aimed at a user who would either use the same workstation all the time or who would log into their own user account. The desktop app setup process, as you know, relies on using the web client to provision the application.
The web client (& the PWA) includes options for existing the client.
Regarding the auto-logout feature you described, please feel free to submit this as an idea but remember to check out the guidelines first.
Why not using different Windows accounts for different users? Than you will not have such problems.
megalmazan
