Update: V15.5 is no longer available. Download the latest version here.
Main features of V15.5
- Web Client
- Integrated Hotel module (Documentation update currently in progress)
- Click to Call Chrome Extension
- Fax G711 fallback
- PDF Reports in LINUX
- Average Talk time per call Wallboard
- UA CSTA + CSTA Module to control 3CX Clients, Yealink, Snom and Htek IP Phones
- MOH Playlist
- Firebase (FCM) (requires 3CX Android client update). This will be available from the Google Play store in the next 24 hours.
How to get the BETA:
Important Note: It is not possible to update from the Alpha to the Beta. The Alpha must be uninstalled along with its clients and then you can install the Beta.
3CX 15.0 will display this BETA update from the 3CX Management console > updates section. Note: Beta updates might contain some bugs so install this only in test environments. It is advisable to install updates to production systems only when they are final.
You can download the Linux version or the Windows version. Alternatively, take it for a spin using our PBX express tool! We’ll configure a brand new PBX for you to try.
Linux: The complete list of commands should look like this:
wget -O- http://downloads.3cx.com/downloads/3cxpbx/public.key | apt-key add -
echo "deb http://downloads.3cx.com/downloads/3cxpbx/ /" | tee /etc/apt/sources.list.d/3cxpbx.list
apt-get update
apt-get install 3cxpbx
Note that for softphones to be controlled from the web client you have to install the latest clients:
Windows: Download Windows installation here
Mac: Download Mac installation here
View the complete change log here.
