Some times explanations won’t do and you need to take control. For that, you need the latest 3CX WebMeeting update with a re-designed Remote Control function to enable you to do just that: take control of a meeting participant’s PC for demonstration or assistance. And to top-up the Web Meeting experience, you can now conveniently send and receive files via the updated “Meeting Chat” to share with all participants. How’s that for a mid-summer surprise update?
Easy Remote Control
The updated Remote Control function was specifically re-designed to be quick and easy to use. No lengthy install, complicated component setup or configuration. Just fire-up 3CX WebMeeting and send a request to remotely control any participant’s PC with these new features:
- Single-step install - the meeting participant gets a link to quickly install and activate the Remote Control client app and allow their PC to be remotely controlled. All done within minutes!
- Bidirectional text clipboard - have the client app installed on both the organizer’s and participant’s sides and share a common clipboard to copy-paste with ease.
- Share any screen - the screen selection dialog now uses the Windows display settings API (Application Programming Interface) to support any number of screens.
- Secure access - full compatibility with Windows security framework, UAC (User Account Control) and the “Run as Administrator” option.
- Minimum requirements - fully compatible with limited-privilege users to simplify deployments in secure and locked-down network environments.
- Record remote sessions - just hit the “Record” button to capture your remote control session via 3CX WebMeeting and get the video at the end of the meeting.
For more info see our step-by-step Video Conferencing for Advanced Users guide.
File Transfers in Chat
This 3CX WebMeeting update also introduces a much-awaited general file sharing function between meeting participants.
- Single-click share - drag-and-drop any file in the “Meeting Chat” panel or just click the “File upload” icon and select a file to share.
- Monitor progress - check at a glance the upload or download progress icon for any shared file.
- Temporary & controlled access - files shared are securely kept temporarily and deleted when the meeting ends.
Requirements & Known Issues
- The Remote Control client is compatible with Windows x64 versions 7 and up and needs to be installed on the PC to be remotely controlled.
- Screen selection intentionally not shown when the RDP target has only 1 screen.
- Sharing is available for file sizes up to 64MB.
View the complete change log.
