Major upgrade to Call Data Records (CDR) System in 3CX.
Following on from yesterday’s V20 Update 6 Alpha release, this post explains the new Call Data Records (CDR) system in 3CX where we’ve streamlined CDR into a single table: cdr_output. We break down the old structure, reveal the new design, and spotlight the technical wins that are transforming how call data works. Read on for full details.
The Legacy Setup: A Fragmented Bottleneck
Originally, 3CX’s CDR / call data was split across four tables: cl_calls, cl_participants, cl_party_info, and cl_segments. Each stored distinct elements of the call lifecycle: timestamps, participant data, and routing details - forcing complex SQL JOINs to piece together a full record. This multi-table design increased query overhead, and bogged down performance for generating reports. For cloud-scale analytics or real-time reporting, the structure simply couldn’t keep up.
The New Approach: cdr_output
We’ve overhauled this into cdr_output, a single-table solution that consolidates all call data into one efficient table. Timestamps, participants, routing, and outcomes - everything’s unified, eliminating the need for JOINs. JOIN is required only for Recording Data which is now in its own table cdr_recordingsout. At 3CX we’ve always been able to scale to thousands of users. This lean architecture further strengthens our scaleability, slashes complexity, boosts query speed, and primes 3CX for cloud-ready analytics. It’s a bold rethink of data engineering, built to deliver precision and power.
Advancement #1: All Your Data In One Smart Table
Legacy: Multi-table JOINs throttled performance—a real headache for digging into call insights.
New: cdr_output packs everything - source, destination, timestamps, outcomes—into one compact table. It’s flat and simple, cutting out the relational clutter so BI analysts can easily follow call flows.
Why It Rocks:
- Faster Queries: Ditches multi-table complexity for single-table speed - queries scale smoothly, no matter the data size.
- Cloud-Ready: Slides right into data lakes or BI tools—no extra prep needed.
- Analyst Win: Call paths are clear and quick to trace, saving hours of hassle.
Tech Edge: Indexes on cdr_id and call_history_id turbocharge PostgreSQL for lightning-fast lookups, even with massive datasets. Keeping call_history_id links in-table slashes SQL overhead, boosts speed, and trims data bloat.
Advancement #2: Every Row Tells The Story
Legacy: Thin metadata left report analysts guessing - why did a call fail? Where’s the context? Who transferred to whom?
New: cdr_output embeds a rich attribute set:
- termination_reason (e.g., “cancelled”, “dst_participant_terminated”)
- termination_reason_details (e.g., “forward_all”, “completed_elsewhere”)
- creation_method (e.g., “route_to”, “divert”)
- creation_forward_reason (e.g., “polling”, “busy”)
- continuation_reason (e.g., “polling”, “forward_all”)
Impact:
- Total Clarity: Every row is a full story - no more piecing together clues.
- Smarter Insights: Powers KPIs like drop rates or queue stats, no extra work required.
- Endgame Explained: Instantly see how, why, when, and who ended a call.
Tech Edge: termination_reason_details fuels pinpoint analysis (think SQL GROUP BY from Grafana or PowerBi), while the UUID-based cdr_id is now GUID standard 00000000-01db-87c1-1bab-07aa0000000d to allow BI tools nail date-time and call order right out of the box. It's all there - how a call started, moved and ended.
Advancement #3: Who's Calling Who, Made Simple
Legacy: Participant roles were poorly defined - source vs. destination required cross-table inference, guesswork, nested operations, Multiple JOINS and performance hogs.
New: cdr_output tames previous SQL JOIN tangles with a series of cleanly split features:
- source_participant_id (used for tracking)
- source_participant_phone_number (e.g., “+1305305305”)
- destination_dn_name (e.g., “Dana White”)
- Flags like source_participant_is_incoming and destination_participant_is_already_connected
| "source_participant_id" | "destination_participant_id" |
| "source_entity_type" | "destination_entity_type" |
| "source_dn_number" | "destination_dn_number" |
| "source_dn_type" | "destination_dn_type" |
| "source_dn_name" | "destination_dn_name" |
| "source_participant_name" | "destination_participant_name" |
| "source_participant_phone_number" | "destination_participant_phone_number" |
| "source_participant_trunk_did" | "destination_participant_trunk_did" |
| "source_participant_is_incoming" | "destination_participant_is_incoming" |
| "source_participant_is_already_connected" | "destination_participant_is_already_connected" |
Impact:
- Precision Mapping: Call direction is obvious - source to destination, done, streamlining flow analysis.
- Complex Scenarios Handled: Seamlessly tracks multiple queue flows, bi-directional trunks, and multi-layered transfers in a single schema.
Tech Edge: Boolean state flags mirror a data warehouse’s dimensional modeling, optimizing WHERE clause performance. The UUID standard in participant IDs ensures seamless integration with BI platforms, preserving call leg sequencing out of the box.
Advancement #4: Timestamp Granularity
Legacy: cl_calls offered basic start/end times; cl_segments fragmented the rest.
New: cdr_output delivers three pinpoint timestamps: cdr_started_at, cdr_ended_at, cdr_answered_at.
Impact:
- Sharp Metrics: Grabs precise ring-to-answer times - every second counts.
- Analytic Simplicity: Single-table calculations replace multi-table aggregations.
Expert Insight: UTC timestamps (+00) ensure consistency across regions—a must for global cloud deployments feeding into tools like Snowflake or BigQuery. The GUID-based cdr_id ties these timestamps to call legs, giving BI tools a native understanding of sequence and duration. No tweaks needed.
Advancement #5: Built for Growth
Legacy: Multi-table setups were stiff - new features meant a complete schema sprawl.
New: cdr_output is a single, extensible table - add a column, and the system adapts.
Impact:
- Future-Proof Scale: Grows with 3CX’s roadmap without relational overhead.
- Operational Efficiency: One table to index, replicate, or partition - built to be cloud-native by design.
Expert Insight: Flags like processed and migrated streamline data pipelines, enabling seamless integration with Apache Kafka, AWS Athena or Kinesis and Google BigQuery. The call_history_id linkage within the table accelerates related-call queries, keeping performance tight and data payloads lean.
Next Step - Getting Cloud Data Ready
We’ve transformed a clunky CDR system into a modern scalable call reporting table. Our benchmarks show queries blazing up to 10x faster - fewer JOINs, richer data. Happy Reporting!
Get Started with Update 6 Alpha
To try out these new features, upgrade to V20 Update 6 Alpha.
Join the V20 discussion in our dedicated Partner or Customer Forums. Follow us on X and LinkedIn to stay-up-to date on latest news and feature releases.
