Snom, Fanvil, Yealink and Grandstream new firmware versions and fixes.
We’ve got an update on firmwares for router SBC phones - most of which are fixes. Read on for more details.
Snom - Router Phones (Fixes)
- New firmware version 10.1.159.12 for D8XX (D862/D865) Router phones fixes the following issues:
- Server Conferencing
- FW update process now visible on the screen
- FKeys pagination
- FKeys visible during an active call
Fanvil - Router Phones (Fixes)
- New firmware version 2.12.16.20 for V62/V64/V65/X4U-V2/X6U-V2/X7-V2/X7C-V2/X210-V2/X210i-V2 Router phones fixes the following issues:
- SBC will automatically reconnect if the internet was down for more than 5 mins
- Responsiveness Issue: Fixed memory leak
- Fixed an issue with CANCEL - it was leaving missed calls on the screen
- Fixed SBC Log to show valid data
- Fixed a download of the nonexisting “version.txt” file - the file will not be downloaded anymore
- Fixed multiple timezone issues
- Fixed translation issues
- New firmware version 2.12.16.22 for X5U-V2 Router phones fixes the following issues:
- SBC will automatically reconnect if the internet is down for more than 5 mins
- Responsiveness issue: Fixed memory leak
- Fixed BLF issues
Follow this guide to upgrade your Fanvil firmware.
Yealink - Firmware (Fixes)
- T5 Series (T53/T53W/T53C/T54W/T57W) - FW 96.86.0.76:
- Yealink headset improvement
Follow this guide to upgrade your Yealink firmware.
Grandstream - Firmware (Fixes)
- GXP 21xx (GXP2130/2135/2140/2160/2170) - FW 1.0.11.74:
- Added support for new HW versions
- Fixed device freezes after SRV failed
- Fixed devices freezes when using SIP TLS
- Fixed the values of Remotename and Remotenumber not being returned when running the CTI command
- Fixed device improper handling of SIP 301
- Fixed device LCD displaying abnormally after downgrading to certain firmware
- Fixed device SNMP query of DND status returning wrong value
- Fixed speaker volume so can’t be changed from device menu even when option Lock Speaker Volume is turned on
- Fixed certain alias that do not work correctly with alias config file provisioning
Tell Us What You Think
Tried and tested! We know you like our product as much as we do. We value your opinion. So let’s meet in the Forum. We’re looking forward to your feedback!
Stay Informed
Hit the follow button on Twitter and LinkedIn for blog updates.
