Phone System
- Improved extension updating procedure
- Improved Backup and restore procedure
- Added support for backups from version 6,7.0, 7.1
- Added: CDR features - Passive and Plugin loading
- Added: Orbtalk Voip Provider template
- Added: Sipgate trunk
- Added: Sangoma templates A102
- Added: fw to external number + rebound in available profile
- Added: Cellip VoIP Provider
- Added: Caller ID reformatting BETA + Added parameters for saving the caller id formating rules - Only available through custom parameter table. BETA -
Added EXT_REFMT_LOCAL_PREFIX EXT_REFMT_NATL_PREFIX and EXT_REFMT_INTL_PREFIX as part of the reformatting outbound calling for extensions. - Fixed: Bug when BLF entries were blank
- Fixed: Bug in restore voiceprompts
- Fixed: Error in the IVR because of IVR caching
- Fixed: Yealink template for voicemail provisioning
- Fixed: Disconnect the call in profiles now sends a busy 486 response code
- Fixed: Recording issue when Barge in is used
- Fixed: Hold and resume operations from a barged in user
- Fixed: Bug in attended transfer - 1 way audio
- Fixed: Bug in provisioning updating when tunnel is enabled
Call reporter
- Fixed: Agent statistics - Now shows correct calls for every agent
- Fixed: Incorrect destination using make call to an outbound external call
- Fixed: Exception in call history
- Fixed: Bug in Abandoned calls for each agent
- Fixed: Exception in call reporter during access of reports
- Fixed: Call reporter allocating a call to a wrong agent
- Fixed: MakeCall + Intercom issue
- Fixed: Blank entries from Version 8 call history to Version 9
Assistant
- Added: Multiple tunnel connections
- Improved: Updating and clean up of old data
- Improved: tunnel connectivity
- Fixed: Bug in provisioning using the Authentication ID instead of the extension number
- Fixed: Updating issue
- Fixed: Bug when user rejects initiating leg of call
Phone
- Added: UI support for handling video brightness, contrast, saturation and sharpness
- Added: Video parameters tuning.
- Fixed: Provisioning, proper handling tunnel's remote port addr as local IP of the PBX
- Fixed: Provisioning, properly saving in the configuration file provisioned data.
- Fixed: Mute indicator
- Fixed: Call History Updating
Known issues
- Server internal error when call is rejected
- If FFDSHOW or 3CXPhone is installed on the same machine as the 3CX Phone System, the 3CX Media server might be affected (depending on the OS). Do not install 3CXPhone or Assistant on the same machine as the 3CX Phone System Server
- Queue cannot forward calls to an external number
- Prompt sets in non-English languages are not complete - blank gaps of audio if non-English language is loaded
- Backups from Version 8 which had digital receptionists created by VAD will give an "Error in the IVR" after restored in Version 9. Delete these digital receptionists and deploy the project again.
- Call History and reports in ring all groups and paging group calls show incorrect destination
- When recording is on, an extra file is being saved which is empty
